Coughed up for a Koffle
Yep , that damper was a bitch to get off. :shock:
Did you have oiling problems with both heads/valvegear? , or was one side more problematic than the other?
Brutus wrote::thumbright:
To be honest, I'm not sure now..... Think one side was more problematic, but again I'm not 100% certain.
Did you find something then ?
Would it of been the pas side bank? , came across it by chance & certainly would,nt of been an easy find , just thinking if all these heads suffer with the same problem.
Seems to be an issue with oil way allignment on one head , if the heads are swapped over problem solved........tis a relatively easy fix so will keep the heads in order they came off.
little one
Mark what is the little plate to the right of the bottom pulley?
Bolted onto the front plate :read2:
Re: little one
Knightcharger wrote:Mark what is the little plate to the right of the bottom pulley?
i would think its the timing indicator,
Re: little one
I guess you mean on the left as you look at the photo ?
If so, Yes, as Dunc said, timing indicator.
