Post
by Pete »
DaveBishop wrote:Yep you are right Les forgot that must be getting old
According to our phone conversation today, you are already old!!!
But you know a lot more about Small Blocks than I do!
DaveBishop
Post
by DaveBishop »
Cheers mate. Bet I can beat you in a 100 yards race.
Hope your back gets better
2 x 1969 Dodge Darts
Post
by Pete »
Very Cruel!!!!
completely kippered at the moment.............
Carl
Post
by Carl »
Yes I did thanks Martin, but I think Paul wants to sell as a complete engine.
*MMA-609*
"Built to be driven!"
Why me???
Carl
Post
by Carl »
I have some figures
Bore = 4.100.5 = +60 over
Piston = 4.095.5
Rings on there = 4.250 I assume this is what +60 rings come as?
*MMA-609*
Why me???
Post
by Pete »
Are ALL the Bores and ALL the Pistons the same size?
Have you / they checked to see if the bores are tapered through wear?
Post
by Pete »
If I have read your data correctly, you are saying there is only 1 THOU clearance between Bore and Piston?
Have I got that right????
No wonder there were signs of over-heating if that is the case - I think you need 3.5 THOU clearance on most US pistons as they are "Barrel-shaped"??
Maybe a BIG Hone will get you out of trouble if all the Bores and pistons come up that size????
TyreFryer
Post
by TyreFryer »
4.1005" - 4.0955" = .005" (5 thou) or am I missing something Pete?
Martin Walker
Post
by Pete »
TyreFryer wrote:4.1005" - 4.0955" = .005" (5 thou) or am I missing something Pete?
I DID wonder, which is why I put the data into Excel - I do not trust my own mathematical abilities!!!!!
It came up with 1 thou.
5 Thou is the wrong answer from Carl's point of view..........
Carl
Post
by Carl »
All pistons and bores came up the same.
I took those bore x piston figures as 5 thou too
*MMA-609*
Why me???
TyreFryer
Post
by TyreFryer »
Don't forget to divide it by two as that's the diameter you're measuring, so you'll have .0025" clearance between piston and bore.
Martin Walker
Post
by Pete »
My old mate always said about air-cooled Moto Guzzi's "If it rattles then it's a good 'en!"
Sadly, this may also apply to you.....not the end of the world....having the correct VTP clearance will be a benefit.
Look at it this way - were you concerned about excessive engine mechanical noise BEFORE your fateful run at the 'Pod?
Carl
Post
by Carl »
1 thou = 0.001" therefore .005 has got to be 5 thou
*MMA-609*
Why me???
Post
by Pete »
TyreFryer wrote:Don't forget to divide it by two as that's the diameter you're measuring, so you'll have .0025" clearance between piston and bore.
DoH!!!
I'm clearly going soft in the head!!!!
Well in, then!!!!
Tight even.......
