I think you have identified the problem yourself. If the car stands outside or is used in winter with salt on the roads at all you get this problem.
Or it could be down to the fluid being old and having a high water content.
front disc brakes
- latil
That could be a partial internal collapse of the flexi,slowing the return of the fluid after application.limelight440 wrote:ive just noticed as well that the flexible pipe connecting to the caliper looks split too,i think these may need attention,allthough no fluid is leaking as yet.
Yep, I'll bet that's it - I've had it happen on a number of infrequently used cars.latil wrote:That could be a partial internal collapse of the flexi,slowing the return of the fluid after application.limelight440 wrote:ive just noticed as well that the flexible pipe connecting to the caliper looks split too,i think these may need attention,allthough no fluid is leaking as yet.
- latil
Sounds like a later lightweight alloy master. Rear/larger reservoir serves front end. Check your rear flexi,might as well change the set while you're there. You'll know their age and you can change the brake fluid.
got my flexs from speedflow, they will match up anything- got there web site off kev
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
heres the web site for speedflow
http://www.speedflow.co.uk/
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
