alternator bracket
alternator bracket
I'm a bit lost here, should there not be a bracket between the alt and the block? It is an a/c car, had young Trev here today and he also thinks there should be a bracket. ( this is how I bought the car way back )
thanks !!
thanks !!
Hi Roel!!
Usually that is one LONG bolt through the front bracket, alternator, spacers to the Cylinder head.
I know my A/C cars have been different though. Some one else may be able to advise - can you post a pic of the set up showing more of the front bracket you are using, this may help with identification, thanks!
- dustymopar
Yes, This doesnt look right - The attachments might help
The bracket is back tofront, and needs a longer bolt & sleeve.
That looks a bit "Home Made" to me....
The Long bolt goes through both lugs on the alternator and there is a removeble spacer that sits between the Alternator lugs, and another at the back between the alternator and the Block.
If Dave is around he will probably have some scans of this in the workshop manual
- dustymopar
Pete, I agree, but that was how it was when I bought the car way back.
All my body service manuels are for '71 Challenger !, but I cannot find a pic of the setup. I have the spacer that should fit between the alt, I guess it means taking it apart then. Dave........
Dusty, I'll pm you about the details, thanks
- dustymopar
