Posts: 13955 Joined: Sun Apr 18, 04 11:04 pm
Post
by Kev » Tue Mar 27, 07 7:39 pm
Not quite up to the same specs as CannonBall, WiseArse or BirdBloke! Here's my Hemi! Follow the build up! Might take some time! The modelling board is graduated in 1" squares so you can get an idea of the size. And the golden nugget helps those not Imperially literate. The block is in several clear pieces to enable easy assembly (and could you imagine the cost of trying to cast a bit of plastic as complex as a block?)
The name is Kev, nowadays known as Kevvy or Pommie C***! </center>
Posts: 22109 Joined: Sun Apr 18, 04 10:49 pm
Post
by Pete » Tue Mar 27, 07 8:00 pm
Cheers, Kev.
That Rocker gear looks a bit more robust than the MP offering.
I hope you line honed the mains and will use plastigauge at the appropriate time...
Posts: 12076 Joined: Tue Feb 01, 05 10:37 pm
Post
by latil » Tue Mar 27, 07 8:07 pm
Don't get glue in your oilways
Trigger_Andy
Posts: 7867 Joined: Sun Apr 18, 04 10:27 pm
Post
by Trigger_Andy » Tue Mar 27, 07 8:09 pm
Will this thing be a fully moving model? Looks
Post
by latil » Tue Mar 27, 07 8:13 pm
Get TrevD to copy all these bits in real metal,nice engine for a tot rod
Post
by Anonymous » Tue Mar 27, 07 8:34 pm
I want one Kev, gotta get some practice in.
Where do you get them?
Post
by Anonymous » Tue Mar 27, 07 8:37 pm
Almost forgot, will this be goin in the taxi, if so will it be ready for the nats?
Posts: 17242 Joined: Sun Apr 18, 04 11:26 pm
Post
by Cannonball » Tue Mar 27, 07 8:48 pm
ADAM get a few more cash jobs in and you could buy my real hemi, i could throw your way a matchin 69 440 R/T SE CHARGER needs resto mild, you could clone it as a hemi car, now that would be a bit off kit wiv your 440 car
Post
by Kev » Tue Mar 27, 07 9:59 pm
Pete wrote: Cheers, Kev.
It appears that the cam is n MP offering, just spent 40 minutes filing all the lobes and having to straighten it with Carole's hairdryer!
Post
by Anonymous » Tue Mar 27, 07 10:28 pm
Duncan ,aint hindsight a wonderful thing ,could've built a hemi with the cash I've thrown @ the engines for the pit.
Post
by Kev » Wed Mar 28, 07 8:14 pm
Last night's progress....
Philth noticed it must be some kind of Bizarre Marine Hemi! Can you spot what he's on about? Cylinder heads next!
Post
by Pete » Wed Mar 28, 07 8:18 pm
No provision for Dizzy?
Post
by Anonymous » Wed Mar 28, 07 8:21 pm
Rotating in the wrong direction, Kev.
Not sure what's wrong with the engine though
Post
by Anonymous » Wed Mar 28, 07 8:37 pm
Domed topped pistons???
Post
by Pete » Wed Mar 28, 07 8:48 pm
Phill440 wrote: Domed topped pistons???
Back of the class for you
Sandy could be right but how can you tell the direction of rotation at the moment?
