posi-locker or spool ??
Spool is basically a big hunk o' metal that replaces the spider gears and/or lsd in the diff, so basically your rear end is welded up. No good for corners and general street duties, but great on a 323 Beemer if yer into drifting.... Posi, Locker, LSD, Suregrip are all sorts of limited slip differential which puts the power down to both wheels when nailed, but allow the differential to work un-loaded on corners, thus saving wear and tear to the whole axle/tyres etc. HTH!
Spools
http://store.summitracing.com/egnsearch ... 4294902616
Lockers
http://store.summitracing.com/egnsearch ... 4294902583
You'll need the gears, plus an installation/bearing kit as well.
Lockers
