what transmission oil?
Hi after replacing the clutch on my 69 roadrunner 4 speed I now want to fill the tranny with oil the manual I have says 140 grade. I have a gallon of Morris EP 140 do you think the EP bit will make any difference or should I get just straight 140?
- Trigger_Andy
i'll wait to get shot down as well
if its too heavy it will make it very hard to shift...try it
bit of an Aussie outback trick however if its too hard to shift due to too heavy oil
dilute the gearbox oil with a 1/2 pint of ATF. no better.... do it again.
wouldn't add too much though
not big not clever and i can't vouch for if it does or doesn't cause the gearbox to wear out quicker but.....
seemingly it works
my gearbox takes SAE30 (odd yes i know but it does)
if you can't get SAE 30
1/2 and 1/2 of SAE90 and ATF does the job.....or so the Australians think....
I just sling morris's SAE 30 in
dave
seemingly it works
dave
is EP140 not a bit high in viscosity?
from the Castrol site (you can download technical data for the oils);
http://www.castrol.com/castrol/sectiong ... Id=7027100
Gear oils here;
http://www.castrol.com/castrol/sectiong ... Id=6009166
Mail order price list;
http://www.castrol.com/liveassets/bp_in ... l_2007.pdf
Tractor Gear Oil
DESCRIPTION
Agricastrol Gear Oil EP 140 is a mineral based extreme pressure multi-purpose gear oil containing anti-oxidant and anti-foam additives to protect against problems due to oil oxidation, gear tooth corrosion and oil foam. It also contains a special extreme pressure additive to cope with the conditions of high rubbing pressures experienced in hyoid units.
APPLICATION
Agricastrol Gear Oil EP 140 is primarily recommended for the lubrication of commercial vehicle spiral bevel final drives. It may also be used to lubricate spur and helical gears where the manufacturers specifies the use of an E.P. oil.
PERFORMANCE
API Service Level GL4
TYPICAL PHYSICAL CHARACTERISTICS
SAE Viscosity Rating 140
Specific Gravity @ 20º C 0.915
Viscosity @ 40º C cSt 453
Viscosity @ 100º C cSt 26.1
Viscosity Index 75
Flash Point º C 261
Pour Point º C -12
Gear oils here;
Tractor Gear Oil
DESCRIPTION
APPLICATION
PERFORMANCE
Viscosity Index 75
Flash Point º C 261
Pour Point º C -12
