'73 Police discs in a '67 Town & Country?
Hi Nick, yes they will fit.
Does you car have a sway bar?
If it does then you have 2 options.
1)Re-mount the sway bar fitting as per an "E" body, cos the calipers will foul it, or
2) Reverse the knuckles and hang the calipers behind ther wheel, BUT....the brake hoses will not fit and you will have to buy after market goodridge-style braided hoses and fittings.
Life is never straight forward.
Alternatively you could fit an SSBC kit or put on 11" R/T style drums if you are running 10" ones for a bit more braking.
A salesman.
Probably bigger diameter rotors.
