WillDatsun wrote:
however, looks like balance is all wrong? if you got the centre of rotation further up you could turn it easier and not have to go as high.
I agree. Try turning your front "bumper bracket" mounts around the other way.
You want the turning axis along the center of gravity of the body shell. Otherwise it makes it very hard to turn as it will always be trying to "fall over".
Craig. You have put the spining axis along the floorpan. No way can that be anywhere near the center of gravity. You need equal mass around all sides of the axis. You have been warned.
always good to think ahead, if your cutting alot out, big car which can easly twist without you noticing.
done a good job considering how much space you have to work with aswell.
Me and my dad put new quarter panels and boot floor in a mach 1 mustang in an area pritty much the same as that, was a nightmare but got it done aventually.
gud luck
