Timing Gear - What is the best??
dustymopar
Post by dustymopar »
Timing gear, what is the best....... :scratch:
Gear drive of chain?
Rolex 8-)
Gears are noisy.
Rollmaster or 440 source billet, I can highly recommend as being good quality and needing no adjustment after having lined up the dots and checking with a degree wheel. Cloyes are the absolute pits, had loads of trouble with them, use at your peril! A good quality chain is every bit as good a gear drive in my opinion.
I use a JP Performance multi-keyway timing set. Found it perfect and not a bad price.
http://www.jp.com.au/Performance.html
dustymopar
Pete wrote:Rolex
My ex-wife helped herself to that some years ago :cry:
Thanks everyone :thumbright:
Pete wrote:Rolex
My ex-wife helped herself to that some years ago :(
Belt Drive................ New Rolex might be cheaper :D
AllKiller
Post by AllKiller »
Miloden Gear drive....can transmit harmonics to the valve train though/ Race critical i think....but fantastic 8-)
ALL KILLER NO FILLER
I have always opted for chains for that reason, Steve...
AllKiller
Post by AllKiller »
True, belt drive being the Ultimate...KERCHINGGGG :lol:
Belt drives are good and pretty easy to set up, but nowhere near as easy as milodon gears, we put a jesel belt drive on the 493 when we re-built it and had one on the belv, and we have a milodon gear drive on the 605, both work great
I'm using a multi keyway rollmaster with thurst bearing behind
from romac in Oz
www.romac.com.au
tiz nice and i've had no issues
gears make a racket that sounds good for the first 500 miles
and then is a pain in the ass
and you can transmit harmonics from crank to cam that have a detrimental effect on anything that runs off the cam. i.e in some engines the dissy and oil pump. if the dissy is gear driven rather than offset dog a Nylon gear can help mitigate (i don't know about anything other than my own which is gear driven)
you could go for gilmer belt drive just to be different
need special pulleys and water pump covers and a good bit of space
and a tensioner
pete walton wrote:Has anyone used the Pete Jackson gear drive ???????
I did, but I found it was Hobbitt-forming...........
Rollmaster off Oz Ebay. Good price, good delivery, good bit of kit :thumbright: 8-) 8-)
