Dave..............................................................
what prob did dave robbbo getAdam68 wrote:Finall got the GVs (thanks Bob) , it does'nt mention the problem Dave R had when he over revved the motor with his 'handy footwork', you would of thought the manual would point this out , cos it looks to me like an easy mistake to make.
Adam68 wrote:Shifted from second over to second , instead of shifting to 3rd , pulling the revs right up , think he bent a couple of push rods , this looks to be a very easy mistake , if you're in second gear you hit the GV floor switch to put you in second over , you then have to shift into 3rd gear wait to hear the change , then hit the floor switch to get you into 3rd , to get into 3rd over you hit the switch again to take you into 3rd over. If you are in second gear then hit the switch , it will take you to second over , if you hit the switch without changing to 3rd gear it will take you back to second gear.
It's ok on the street , but when yer head is goin ten to the dozen on the track , i can see how easy it must be to mess up.
100lb = 1/10th second.........So that makes 1.5 seconds. So what's your estimate? 11.99? Makes mine 10.49? Seems rather unreasonable......Any old excuse, you Big Block Guys!Adam68 wrote:Probably will Kev , near on 1500 lb lighter.Kev wrote:Dude! I have always had you down as a trier! You have now become a doer! I will have fun with you on the strip next year. I'm gonna kick your butt with my bitty Small Block, honest!![]()
