Should I add a mirror?
I find that even with the normal size rear window I need all the mirrors I can get. :shock:
Even then I sometimes get a hell of a blind spot on some slip roads and on some roundabouts (one on the southbound A1 in particular) I have NO idea if there is anything coming or not if I get too far forward.
So I would fit the mirror.
i bought clamp-on RH mirrors for both my cars, they just clamp to the quarterlight frame with allen screws and a padded bar. they are convex so the view is reasonable
yeah, fit the mirror. Easier to fit than a new quarter panel when you side swipe a Sprinter or something in your blind spot.
Agreed, fit the mirror.
I'm looking out for a passenger side mirror for my B body because my drive is only four inches wider than the car :shock:
I can't fit a RH mirror to the Buick 'cos it won't go in the garage then. Yes, its that tight.
I think in the interets of safety no one would tell you off for doing that.
Now go and weld it on in the most horrific manner possible :twisted:
Hey Will
that's a good idea....where did you get that clamp on mirror from?
Cheers
Martin
i got some in my shop somewhere, they clamp to the legsheilds of lambretttas/vespas at about calf height.
i'll have a mooch about tmoz for some and if no joy i could order some no problem.
MrNorm
Post by MrNorm »
Dave wrote:I find that even with the normal size rear window I need all the mirrors I can get. :shock:
Try the convertible! Even worse. SE can't be much fun either....
Ok, i can get two types of clamp on mirrors but i think the stems maybe a little long making them stick out too far.
whaddya think?
They are both about the same size, i would say the round one is the same diameter as "WillDatsun's" and the squareish one a little wider at the widest point.
?17.00 each to yer door.
I think the clamp may need to be "shaped" to fit the window trim/post.
Hi Wildman,
thanks for looking - much appreciated, but as you say, I think the stems are a bit too long.
I think the clamp on idea is a good one though.
Ivor,
you still looking for one of them mirrors? I have a B Body wing mirror sitting in my magic shed as we speak
