6-Pack Manifold Identity Crisis
Hi All,
I have a little problem at I know one, some or all of you may be able to help with.
I have recently acquired a complete, original 6-pack setup from manifold to aircleaner and although it all looks good, there are some strange things on the manifold I dont understand and confuse me a little.
The casting number on the manifold is 2946276 which is correct for a 70-71 cast iron 440 manifold.
But, on the front vertical face, there are two cast holes about 8mm in diameter, one above each other, and both slightly to the right of centre. The lower hole has a pipefitting in it, the upper has nothing, just open. I have checked all my books and I cannot find a photo of a maniflod with these holes in.
Second thing is, how does the coil fit? Is it a special bracket that uses the main fixing bolts? There are no holes anywhere lese in the correct position (passenger side rear end of manifold) to fix the bracket.
Lastly, the manifold has a triangle next to the casting number with the letter "A" in it. What does this mean?
The two holes are the biggest issue because I cant see them in any pictures I have.
Many thanks chaps.
Many thanks chaps.
"how does the coil fit? Is it a special bracket that uses the main fixing bolts? There are no holes anywhere lese in the correct position (passenger side rear end of manifold) to fix the bracket."
There is a specific Bracket for Coils on 6 Pack manifolds - this is obtainable from Year One if you want it to look original.
I have never seen a manifold with cast holes on the front vertical face.
Many thanks Guys.
Dave,
going to be a bit sad but as far as I have read, ally manifolds werent available 1970-71. I am going to restore my 70 RT charger as a 6-p clone so originallity is key. I have chums in US sourcing a ganuine "70" date coded 6-p engine.
Pete,
as far as you know, does the coil bracket use the bolts that fix the manifold to the head for securing?
I am now a little worried about the holes. They look like they are there for a purpose without doubt, but why, I do not know.
Dave,
Pete,
Sorry to keep bothering you both with more silly questions, but if I find those two holes I am on about are not needed (I am starting to assume they arent because you havent seen them before and I cant see them in pictures) can they be filled in anyway permanently, like building them up with weld and grinding back?
Blimey Pete, 40lbs!!!
thats a lot . BTW, Nice spread in Classic Car - the only reason I bought the mag (apart from the Aston article he he) Plymmy is a real beauty.
Thanks for the advice Dave, I think I will take that route.
FINALLY. I am going to re-build all three carbs. Year One do all the hardware. Is it a difficult / tricky job for the uninitiated (although I am more than capable of wielding a spanner)? Should the carbs be that gold type finish and if so, Where would I get that done?
Blimey, you are keen!
Gold is correct, but if you are going to those lengths, buy new ones.
The re-build kits from Holley (Gaskets & Float Valves, not other "Hardware") are ?120 each list price for the 2300 series carbs....now you know why the bidding was not that fierce on ebay recently for such a set up.
Oh. that does not include the outer carb diaphragms either - they are about ?20 each.....
Year One do kits for the 6 pack throttle spring Bracket and Spring (6 pack only items) and also the unique fuel lines to the carbs.
You are about to give your credit card a good thrashing
Setting up a SP initially is one of those life-changing experiences, especially if you have a big cam with lots of overlap.
I STILL like them though as I have had 5 cars with Six Packs (440+6 '71 Cuda; 440+6 Superbird; "A12" 440+6 Roadrunner; 340+6 AAR Cuda, 340+6 Challenger T/A), of which I still have two......
- Dave-R
This is why I said get rid and get the Eddy version. You try holding the iron version at arms length to lower it onto the engine and see how long your back holds out.Clivey wrote:Blimey Pete, 40lbs!!!thats a lot .
I think I paid ?60 for my complete 6-pack system. Plus;
?120 for the Eddy manifold.
?400 for the conversion to manual secondaries (included gaskets and rebuilds - pity because I had already rebuilt them with the kits Pete mentioned).
?1000 in man hours getting the thing working right.
If you want a cheap way to get the colour of the carbs right check out Frost products http://www.frost.co.uk/ as they do a spray paint that looks the same.
