Stainless Steel Trim Polishing Tips
- Dave-R
Anyone got any good tips on polishing stainless steel? In particular the trim bits found on many of our cars.
With the polishing mops on my drill I never get any decent results.
Is this due to lack of sufficient speed? Type of mop or polish?
How can I get good results?
Remember most of those bits are bright anodized. So you have to strip that off first.....and reapply if you want to, though can just polish
Whoops, my bad, sorry about that - I am talking about the aluminium trim (e.g. hood and boot trim pieces etc).
You asked about the stainless - I must pay more attention
Oh well at least you get a bump!
have ya tried
Shiny sinks
tescos do it
brings up the inside of the microwave and the drainer nice
formulated for kitchen grade stainless.
makes everything black and then polishes off to leave a lustrouse shine
works on smooth and brushed surfaces equally well
Shiny sinks
tescos do it
- Dave-R
Yeah. It was speed I needed. The drill just does not cut it.
So I got a polishing conversion kit for my bench grinder. What a difference!
I tried it out on a bit of old used trim I wanted to use as a replacement for a damaged bit of mine. It is hard to photograph because it is very mirror like now but I placed it over the other half that I have not polished yet and hopefully you can see the difference. The walls of my garage are yellow hence the yellow reflection in the metal.
Ok, looking for a little more detail here on what has already been said.
(I have bought the complete buffing kit from Forsts, and have a bench top wheel so mop speed 'shouldn't be a problem').
So, Some of the stainless I have would polish up very nicely with just some autosol and a rag by hand, but other bits have some slight scratches in which I assume, would need buffing out. Now I am not sure whether the buffing wheel will end up blueing the steel, burning through it etc. etc.
Should I be looking to use every stick of polish throughout the process? I.e. each different grade of coarsness right down to the jewelers rouge? Or is that unnecessary? The scratches arent that visible, I am just anal about the whole thing but don't want to wreck anything through an exercise in futility.
- Dave-R
Stop being a girl.
Use the three mops in the kit with the correct three polishes for each one.
Only put a very small amount of polish on the mop. But put a little on frequently.
Too much polish on is a pain as it sticks to the metal.
The first mop is the most agressive and will leave the finish dull. But this is the mop that will remove the scratches. Work at 90 degrees to the scratches. Then finish in different directions so you are not just polishing the same way all the time.
The middle mop will bring up the shine. The last mop will only have a minor effect on stainless. I wouldn't bother with the powder on stainless.
