So here's the story.
Bought Camaro not running right, thought it would be quite an easy fix. Big job was clutch, sent to local garage for change. On collection alternator not working and voltmeter at bottom of gauge. Had to use as no other car so battery charged. On way to garage gauges stopped, fuse blown and replaced. Car would not start and finally did but with backfires. Sent for Engine Temp Sensor, O2 sensor, plugs, HT Leads, air filters and alternator.
Now car running fine but still not charging the battery. I've measured across the alternator and am getting 11 volts but only 10 at the battery. Tried putting a jump lead on the connection but no change.
Please help!
I've been using the Dart everyday, it's fine but I'm using too much petrol. Heavy Right Foot on these lovely Scottish roads!!
Not Mopar, Chevy Alternator driving me nuts...
Guys, here's what I've found so far...
Can't turn Alternator by hand whilst belt is engaged.
It's got 1 plug with 3 wires coming out
Voltage reg...Can't find one. No mention in Haynes. Battery wire and Alternator wire meet at an junction, made of plastic and you can see the join. Hmm.
The self diagnosis thingy says "No reference pulses to Electronic Control Module (ECM)."
So I guess I've got to find that under the dash. Bugger.
The regulator is inside the alternatorautoholic wrote:Guys, here's what I've found so far...
See if any of this helps you.
http://www.madelectrical.com/electrical-tech.shtml
Reset the codes on the ECM and try again. 'No reference pulses' inplies a signal from a sensor to the ECM rather than a voltage problem from the alternator. Alternatively, try any of the Third Gen forums.
http://www.camaroz28.com/forums/showthread.php?t=581540
http://www.camaroz28.com/forums/archive ... /f-20.html
http://www.z28.com/forum/archive/index.php/f-75.html
http://www.z28.com/forum/archive/index.php/t-46190.html
http://sethirdgen.org/cs144.htm
http://www.thirdgen.org/techboard/elect ... iring.html
