Given that you don't have to worry about what will fit within the bodywork, suspension etc. (i.e. you can fit whatever size you like) what governs the decision on the ideal width and diameter of rear tyres for drag racing?
I imagine diameter may be dependant on gearing/rpm and the width on torque/power? Or is it just a case of bigger is better?
Ideal Rear Wheel/Tyre Size
Martin Walker
- mopar_mark
Re: Ideal Rear Wheel/Tyre Size
TyreFryer wrote:Given that you don't have to worry about what will fit within the bodywork, suspension etc. (i.e. you can fit whatever size you like) what governs the decision on the ideal width and diameter of rear tyres for drag racing?
Most of the times, the size of tyre/rim is dependant on what class you run in.
eg Prom mod can run 16" x 16" , Super mod restricted to 15" x 15"
By changing/playing with Converter, Axle ratio & Tyre & Rim diameter, you can also tune to suit type of motor used (High revver, high torque, etc) also adjust to suit suspension/car set up. ie heavy hit of the line, higher top speed with larger diameter wheels, etc, etc.
As for the width, the more surface area you have the easier it should be to gain traction, assuming suspension is working correctly and you have enough motor to turn the tyres.
Then again if you have ever seen the 10.5" tyre class, all of this seems to go out the window, those boys are awesome. Some look quite hairy with the amount the move around.
