'69 Charger Grille restoration - daft question
...which is..."can you change the trim, such as the "I" section on the car or do you have to take the Grille out to fit it?"
The front is ready to be re-installed but the trim is not ready to go on - can it be done at a later stage or does it have to be fitted before the grille is mounted to the car.............
Cheers.
Pete , should be staring you in the face , you've already got it out. :?
Adam68 wrote:Pete , should be staring you in the face , you've already got it out. :?
Sounds like a case of :-
Can't see the Woods for the Trees
:drwho:
:oops:
Just re read my post , did'nt mean it to sound as harsh as it did. :wack:
Do i have to spell everything out?
I wanted to know if I could put the grille together with the parts I have now and upgrade at a later date............ :roll:
