Why do you want to use cut to length pushrods ?pete walton wrote:Any one got any tips ,wheres Dave when you need him
I made simple pushrod checker using an old push rod, with threaded insert in the middle.
I could then adjust push rod to desired length, then measure & had them made to my exact requirements.
I found there was minimal difference in cost with Custom pushrods cut to required length compared to regular pushrods.
This option then gives you:-
Length you need
Choice of wall thickness choice/ Tapered wall, etc
Choice of end - Ball, Cup, etc.
If you want to go with cut to suit, then my advice would be:-
Measure twice, Cut once
Get decent vernier or micrometer for measuring
I would cut to rough length using hacksaw & finish to length using lathe.
Would use dab of grease before "pressing in" your choice of end.
I would probably start to press the end in using lathe & finsish using small fly press.
If you dont have access to lathe then mark pushrod using tape on circumferance & cut near to tape line with hacksaw & finish to length using a medium cut file.
Use small dab of grease before pressing end, depending on interference fit I would tap in using hide mallet & gripping pushrod in vice. Use soft jaws or piece of rag to stop vice jaws damaging the tube.
