Removing yoke from pumpkin?
Looks like its held with one big and very tight bolt. Anyone know if this is a normal thread to remove and what torque seting its held by?
Mick, the yokes ( I have two) are on the garage floor currently. Dave, thanks for the scan.
Next query -Is it a 'simple' case of unlock bolt, swap yokes and do up nut, or does the tightness of the nut impact on pinion settings ie if a torque up can i damage anything inadvertantly?
Pumpkin is 741 unit
Pumpkin is 741 unit
tightness of the nut has a direct impact on the preload of the pinion bearings hence there is a minimum torque setting.
ideally the carrier should be removed ( so the crown wheel has no effect on turning torque of the pinion) pinion nut is then torqued to the minimum setting and then checked for turning resistance with an in/lb torque wrench
sure the figure is 15in/lb with old bearings and 25 in/lb with new bearings, best to check that though
with a 741 case it doesn't matter if you go a little high as you can back the nut off and do it again as there are preload shims, 489 case with the crush sleeve you need a new crush sleeve and if you go too high you will need another
I've had similar advice but to brace it againt the frame of the car- some (eg Ford 9") can require as much as 3-400lb so your floor might not be an ideal strong point...Mick70RR wrote:You don't need an air tool, just use pipe grips to hold the yoke against the floor of the car.MilesnMiles wrote:Thanks Dave, sounds like an airtool job
If you are talking about the 'crossover' UJ, then yes that is oft-used and allows mating a prop to a yoke when one is a 7290 size and the other a 7260. Is that what you are trying to achieve? I had one on my car actually. Very cheap in the US, £50 or so over here!!!MilesnMiles wrote:Think I may have a solution, possibilty of an adaptor set up that allows big yoke to small yoke. Need to contact Hauser. With thanks to Blue
