Bench racing
Jon
Post by Jon »
14.8 :D
Re: Bench racing
pete walton wrote:Bored today all me chores are done chicken in the oven wifes up London me garage is empty so how fast is me old dragster gonna go???
440 ish
11.1 comp
.590 cam
9 inch verter
eddy heads ported a bit ;)
tunnel ram twin 650 dps
studed mains
fully balanced
milidon single external oil system
MSD dizzy
Msd 6
4.56 gears
32 inch rear wheels
What will she run??????
pete walton wrote:32 inch rear wheels
Blimey, what size tyres you gonna get for those rims :D
Pete,
What do you estimate the weight of the car to be ?
11.2s all set up correctly n driven proper, ;) :D
pete walton wrote:2900lbs approx
10.9
Need to get some more weight out Pete, few hours with the holesaw should help address that problem :D
pete walton wrote:I was hoping to squeeze a ten eventually with this set up so looks promising ,as Duncan says set up and driven properly helps :lol:
I wasn't joking about the weight, mine was around 3,300lb's when I started out. With full cage, me sitting in it, its around 2,200lb's. OK,OK, I put some weight on so closer to 2,250lbs :D
That was with the B Block & B1's, will scale it in next few weeks to see where its at with the Hemi, Blower, road trim. I'm guessing the KB Block & Blower will be fairly similar in weight to the old engine.
If its gained to much, will have to start looking where I can save some weight. I even holesawed the headlight buckets ? as was concerned about the weight going back up with the raod trim. Plastic bag, instead of washer bottle, might drill the nuts & bolts next, swap for aluminium bolts where I can. Keep me busy for a few weeks :D
Skin head and cut yer pants off before your run. Worked for me :thumbright:
Mick
Post by Mick »
What does the convertor stall at.
What did you get out of the old set up Pete?
Mick
Post by Mick »
113 is good enough for 11's
BUDGIE
Post by BUDGIE »
I think Pete ment gas mark 113 .......... ;)
:lol: :thumbright:
