Torqueflite problems
Re: Torqueflite problems
terrysd455 wrote:checked the operation of the newly fitted B&M pro,
You recently fitted a new shifter?
Cable operated?
Make sure it is not routed near the exhaust as heat can make the cable longer and that will give you problems selecting the gears correctly.
andyrob
Post by andyrob »
you need to be pm' ing cannonball or blue they are the box guyes
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
very strange, you need to work the shifter and have someone under the car check the arm on the trans is moving as you move the shifter,
if all is well figure a v body fault or the trans needs to come out for a rebuild reseal,
But it worked OK before you fitted the shifter?
I still think it could be the shifter cable.
Always double check the simple things first.
My car would refuse to start in Park when hot and not quite go into gear quite right sometimes.
I re-routed the cable and insulated the part near the exhaust as I realised that heat effected the length of the shifter. Therefore the selector lever position.
It was much better after I had re-routed and insulated it.
I could get all the gears even when hot. But still just occasionally I couldn't start the car in Park. No big problem because I just shifted to Neutral and started it there.
But also I don't think the gear selector lever that came with the shifter is quite right.
I think the hole for the cable end is in slightly the wrong position. Which means the reach of the lever is altered.
When things start working differently the first thing you do is look at what has altered.
Standing in traffic shouldn't have any effect on your transmission function.
I would seriously consider fitting a neutral switch.
:iagree:
Or buy yourself a Kawasaki H2...it would be safer! :D
mad machs
Post by mad machs »
:laughing3: for sure, those things were not a major contribution to road safety :shock:
Mike that is called Mike.
69 Dodge A108
73 Mach1 Mustang
Absolutely right Mike, I had one back in 1972, for about two months...I gave up riding it then because I knew I was gonna die!:shock:
Ivor wrote::iagree:
A better animal was the H1, handling wasn't in their dictionary :D :D When the center plug wasn't fouled & motor was running well, then that was one hell of a ride :shock:
Hard to believe they followed virtually with the Z1
