Mind the gap, Windows
Side windows have gaps at the top when wound up, sould there be a spacer between the trim that screws to the roof, that the seal sits in?
Also rear 1/4 windows seam to sit to far to the rear, resulting in a gap between that and the door glass.
Any ideas? umm just a though, wounder if a can ajust it where the winder mech, bolts to the door. :shock:
The glass is adjustable.
, :shock: Adjustable glass? does it stretch. :lol: :lol:
sorry :oops:
What do you mean?
Can you adjust where the glass fits to the winder mech, or do you mean where the winder mech bolts to body,
thanks for quick response :thumbright:
steveo
Post by steveo »
slacken off the the bolts that attach the up stops for the rear glass .. then wind up the glass to desired height ..then re tighten :thumbright: ....
steveo
Post by steveo »
:D
Alex Doig spent 1 whole day adjusting the drop glass on my Superbird - it is tiresome, but can be done.
Glass
Yes Pete but then nothing but mm perfect for Alex he da man :thumbright:
Craig.
The glass can be moved in and out at the top and even tilted fore and aft.
Where is your workshop manual?
you'll probably find that once its all right and matches up nice that when you open and close the window with the door shut that the metal trim strip on the front door glass gets inside the rear window
two chioces
1) throw a massive hammer at the car and storm off into the house
2) spend two days re alining the door at the hinge bolts that bolt into it not the A pillar.
but then you will find the door doesn't shut properly
two choices
2) spend 2 days adjusting stricker plate on lock the big bolt that the lock clicks onto and then of course the fore and aft alignement of the door, that's the bolts at the hinge into A pillar.
at this point the door bottom will slip off the pad you have on your trolley jack and remove a large area of paint
but once done youll find that the rubbers at the front top of the window and along the roof line have been so compressed for so long that wind noise is now unbearable
you have two choices
1) throw a big hammer at the car and storm off into the house
2) slow drift into mental illness, life of crime,prison, suicide.
or
buy some new rubbers
however
you will find the new rubbers are not quite right.
START at the TOP again
been there done that now just drive with the window open
life can be even more fun if your doors are not the orginal ones from the car. at the factory they just took off an akward door and lifted another from the pile.
steveo
Post by steveo »
:laughing3: :laughing3: :laughing3: ............ good one Dave that is so true :thumbright: aligned all the original doors to paint mine ..... once painted spent the whole weekend putting the glass & winders back it & re- aligning all the glass ... come to fit the new weather strips /rubbers .... nothing fits good :x SO annoying :banghead: spend another weekend trying adjusting every thing ..... still have to slam the doors shut .... :runaway!: :violent3: :angryfire: :pub: ..... leave the car for 6 months with the doors shut ... hoping the rubbers would have
compressed ... :D .... go & open the door again ..exactly the same ... :banghead: ... spend a whole day cleaning up the original door rubbers & roof rail rubbers removing old over spray etc .....re fit them spend another 2 days realigning ..to get the every thing opening & closing /fitting as i want .. :roll: :D
:evil: :P me too :x
Doug
Post by Doug »
Dave999 wrote:you'll probably find that once its all right and matches up nice that when you open and close the window with the door shut that the metal trim strip on the front door glass gets inside the rear window
two chioces
two choices
or
however
Torch it :D
MOPAR - Move Over Power Arriving Rapidly
Blessed is he who, in the name of charity and good will, shepherds the weak through the valley of the darkness, for he is truly his brother's keeper and the finder of lost children. And I will strike down upon thee with great vengeance and furious anger those who attempt to poison and destroy My brothers. And you will know I am the Lord when I lay My Mopar upon you
Alined all mine first time , what's all the fuss about. :dontknow:
:D
Brutus wrote:Alined all mine first time , what's all the fuss about. :dontknow:
:D
We need more Professors on this forum......... Dr Brutus has a full time occupation answering all these questions :D :D
Dave999 wrote: 1) throw a massive hammer at the car and storm off into the house
:lol: made oi larf
On a related subject- how do you remove the weatherstripping that wipes the glass as it goes up & down?
Those rusty stumps holding them on, were they screws or clips or rivets?
Do i have to remove the glass?
If thats the case, aside from the obvious (marking the bolt locations, not breaking the glass, etc) any tips?
