Post
by Anonymous » Fri May 23, 08 11:55 pm
does anyone know what the timing should be for my 340/416? got it at i think 5deg
Posts: 6738 Joined: Fri Jul 14, 06 8:01 pm
Post
by mopar_mark » Sat May 24, 08 12:33 am
strokerblue72 wrote: does anyone know what the timing should be for my 340/416? got it at i think 5deg
Cant answer your question Si, but it definitly aint 5 degrees
Probably closer to 35 degrees ?
Post
by Anonymous » Sat May 24, 08 1:20 am
Simon , the motor will tell YOU where it wants to be , carry out a kickback test , look in the tech section , plenty of info there.
At 5* initial you will kill yerself with the unburnt fuel , is this a smog motor.
I'm sure Kiwi will sort it out , or have you messed with it after getting it back?
Post
by mopar_mark » Sat May 24, 08 1:22 am
Brutus wrote: or have you messed with it after getting it back?
Ahhhhh ..... good point Brutus
Post
by Anonymous » Sat May 24, 08 1:37 am
Can't see Kiwi leavin it like that , or not offering to set it up when the motors in.
Post
by Anonymous » Sat May 24, 08 7:59 am
Brutus wrote: Simon , the motor will tell YOU where it wants to be , carry out a kickback test , look in the tech section , plenty of info there.
spot on mate thats just right
the motor will tell all
Post
by Anonymous » Sat May 24, 08 8:53 am
10 degress btdc
Post
by Anonymous » Sat May 24, 08 9:14 am
5* will kill you with fumes inside a minute, 10* won't be much better
get a kickback test done then get the distributor recurved
Post
by Anonymous » Sat May 24, 08 1:25 pm
Agree will but the book says 10btdc to start but this of course dosent allow for wear and teat or any other factors i do the intial to the book then by ear
Post
by Anonymous » Sat May 24, 08 4:35 pm
book is coming up to 40 years old mate, and stock camshaft and much better fuel
it will at least need to be 14 and then a load in the can
Guy
Posts: 5002 Joined: Sun Apr 18, 04 10:20 pm
Post
by Guy » Sat May 24, 08 5:46 pm
I used to run 18 at base it would start to ramp at 1400 rpm and 34 all in at 3000and that was bang on for my 340, being a stroker motor it will probably take more total.
Post
by Anonymous » Sat May 24, 08 7:37 pm
it was kiwi that set it up it was all guess work
Post
by Anonymous » Sat May 24, 08 7:38 pm
Wil wrote: 5* will kill you with fumes inside a minute, 10* won't be much better
hoping to talk you into hte recurve mate
Post
by Anonymous » Tue May 27, 08 8:36 am
Simon
replied to Kiwis email this morning mate
