Got this from another thread, just below this one about shocks, might help?
[Southern Boys use Paddington Springs, they are the Dogs ....In Vemberly
0208 7953300] quote!
rear springs advice
I use Brost Forge in Islington, cost about £180 to redo the last pair I took in there. Never had to wait more than a week to 10 days for them to do them. They don't do the original style clamps but no doubt you could get a set to send them. Call them on 02076072311, they do quite a lot for classic car owners.
- Dave-R
I am starting to remember things.
The height the car sits at is determined by the spring rate and the spring camber.
The spring rate is fixed by the size and number of leaves in the spring. So unless you change the number of leaves the rate is not going to change.
So you just need the spring heated and re-curved to regain your ride height.
