oil preasure gauge acting strange
I didn't want to mention anything, just in case you'd changed the post after John had replied.
My first port of call would be to check the actual sender wire and make sure that the gauge isn't earthing, because I think I'm right in saying that, like the fuel gauge, if it's earthed it'll send the needle right over.
I bet Dave 999 would know, he's clever like that...
naa mines never gone wrong and is made by VDO (not a US supplier to Mopar in them days) so i know little about them but based on other guage fun ive had here is some stuff
there are a few things you can try
2 types of oil pressure sender
1) one wire:- 1 wire to the sender only . in which case the sender earths to the engine block through its variable resistance. and has 1 connection to it from the guage (the guage will have 2 wires)
2) 2 wire:- 12volts into sender on the first wire and a variable voltage out of the second contact up a wire to guage which earths through its pointer windings to the case/dash/carbody
i.e you will have a 2 wire guage with a 1 wire sender or a 1 wire sender with a 2 wire guage
what you do from here depends on what style guage you have
Ivor is probbaly correct
one of the wires will have blown around in the wind for 30 years and will have worn through. most likley up front where its hot windy and vibratey
disconnect sender
measure resistance between pins on it and the body as the engine is reved
one of them should make the meter change => sender ok
check back of guage
how many wires
what happens when disconnected
what happens when not earthed to dash pod
a 2 wire guage has a supply wire and a signal wire
a signal wire that is shorting will make the guage go to one extreme or the other
diconnect signal wire and instead earth the signal contact to the metal body via a graphite pencil the guage should move a bit if its ok as you have just replaced the direct short with the small resistance of a 15 cm chunk of graphite (use a resitor if you have one most people have a pencil)
1 wire gauge
body of guage is earth and must be connected via screws to dash pod which is connected to body of car.
in this case the guage is powerd by the feed from the sender if you disconnect the sender regardless of of if the wire to the guage is shorted or OK the guage should do absolutly nothing it has no way of getting any power to do anything i.e no movement at all when you switch on the ignition
PS any 3rd wire on a 2 wire guage or second on a 1 wire guage will be for a back light to the guage (this should be quite obvious as to what it is)
take out the bulb and use it to power the guage (with the/head lights/dash lamps on) if you suspect the guage power feed to be knacked.
remember there is nothing wrong with connecting up a small houshold battery with two wires
use the negative for earthing duty and ping each connector on the back of a guage with the positive. usually indicates if the guage is alive still and punts out such low current that you won't knack anything
the little oblong 9 volters from stuff like walky talkies and baby alarms are demon for this kind of thing
disconnect sender
check back of guage
how many wires
1 wire gauge
