Changing a dizzy - going electronic - 318 in 70 dart- advice
Dart Vader
Post by Dart Vader »
318 in 70 Dart
following my breakdown last week I'm going to fix the car this week
1, Any tips on taking a dizzy out, thought they can be little buggers to get out?
2, If changing from points dizzy to electronic one are there any changes to the wiring to do?
Cheers
J
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Err. You remove a bolt and lift it.
And yes. The wiring is a little different.
I put a pertronix in mine, easy to fit and only one wire to cut into, easy and cheap.
Have you bought the full kit? dizzy,orange box,ballast and a bit of wiring with a plug on. If you have,the instructions are in the box. :D
Dart Vader
I know you un-bolt it :) .......just had heard they can still stick a bit
I've just got a spare used leccy dizzy from duncan last year so just gunna throw that in
Love to have the orange box combo but funds not allowing yet, however did find a flamethrower coil whilst rooting around.
Just wondered what the wiring was going to do more than anything, don't want to cut cables etc
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
you need the orange ecu to run leccy dizzy
Justin , post exactly what you have & someone on here will guide you through it.
You got a 50/50 chance of gettin that dizzy in the right way round , you feelin lucky? :D
the dodge
Post by the dodge »
what happens if you get it the wrong way round?
Guy
Post by Guy »
It wont start ;) and you will end up loosing your hair/eyebrows whilst trying, been there done that etc, etc :oops:
Guy wrote:It wont start ;) and you will end up loosing your hair/eyebrows whilst trying, been there done that etc, etc :oops:
and will put a nice flame out off your carb ;) :D
the easy bit is swappimg the dizzy, take the cap off locate rotor position and vac can position and fit the replacement in THE SAME, then ask someone on here how to wire it and yes you need the leccy box and the ballast
Dart Vader
Just gunna drop in some spare points then for the time being.
Must go leccy though sooner or later
Don't like the idea of losing my hair, if it doesn't gert burnt off I'll probably pull it out due to stressing that I can't get the car to work !!
Cheers fellas :thumbright:
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
can help you convert a non electronic car to electronic without much expense
its easy as well
you need 1 leccy dissy
2 piggy back lucar style spades
1 loop of wire
4 standard spades
pair of plyers
1 4 pin HEI module out of a chevy
12 volt coil any v6 bimmer jobby will do
job done
basically
1) wind engine round to TDC
2) pop off dissy cap check where rotor points. if its not at no. 1 wind round to TDC again. it will be then i promise
3) Mark dissy edge with chissel at end of rotor
4) transfer mark to new dissy
5) duck tape new dissy rotor into that position
5) put in new dissy in approx same place
6) transfer all leads to new cap
new dissy is in
however
thats only half of it
get 4 pin HEI module
bolt to bit of angle iron
hose clamp it to dissy
wire it up as per diagram
then
go to ballast resistor and put loops of wire across it
2 pin ballast join pins
4 pin pin ballast join top 2 together and bottom 2 together
then put in 12 volt coil blaster flame thrower or whatever you like as long as its a 12 volt one
job done
if it won't start then the dissy wires are back to front or your module is knackerd
does everything an ornage box does for a lot less money
Oh yeah
need to reset ya timing
what a mess lol, bugger that buy the complete kit from summut lol
well the diagram is.....
i am less artisitc than the bloke that drew that and its always easier to nick something
the idea on the other hand has some merit
standard or orange box and HEI module are designed to do the same thing. Mopar box was invented when it was all seperate components.
the HEI used a new fangled Motorola chip licenced to Delco
one is 1972 tech. and one is 1976. tech so there is not much in it in car terms but in semiconductor terms its a 486DX66 to a pentium 2
i guess they both now use a chinese copy of the obsolete motorola chip as it has been ripped off by all including Bosch siemens Napa wells nordoff
the HEI module is water and oil proof and is potted in hard plastic
its a bit more robust than the mopar unit. i.e never bulges or oozes out tar
the HEI module can run a modern laiminated frame coil which in theory can allow a higher current to flow. something that i belive the FBO version of the mopar box can do but not any others of standard is configuration
higher current into coil in the same time slice = more energy especially if the coil has more windings crammed into it
i.e higher voltage and higher current = all round better
so its a step up from a standard mopar box
seems to be a step up from an orange box if you use it with a good 12 volt high power coil and the module you use has surpassed the 2-3 amp limit of the standard all branded repalcements manage that these days
to come anyhwere near the FBO you would need to get a petronix or Accel module and a matched coil....i'd go with the FBO it would probably work out the same and you get the benfit of recurve of you dissy if you go the whole hog
but for a street car its just fine and dandy provided your dissy still provides the kind of advance curve you want.
modern modules are good to about 6000 rpm the orginal was not
Chrome ornage and standard claim to be good to differening RPMs but you see them getting a right slagging for poor operation out side of normal RPM ranges i.e low energy and missfires abover 5500....i guess that prompted FBO to do the work they have done.
i had the dissy and the coil i spent approx $36USD £17 on a module and pennies on connectors
it works well and has done for 4 years
