collapsed lower joint?
latil wrote:That's why there's a grease point on the joint
also ball joint rubber boot gets damaged some how , lets water in causes the it to rust over a period of time
sorry to see that happen
- latil
When I started on the Fury,the lower ball joints were fairly worn,replacement was one of the first jobs. FSM suggests that maximum wear/free play should not exceed 70 thou,mine were close to that and that much movement is enough for MoT failure.When I inspected the old joints,the top enclosure of the ball,the bit under the rubber boot,was full of radial hairline cracks and could easily have failed. What I don't know is whether these cracks were from years of hard use on rough roads or if the damage was caused by the ball joint splitter.
- latil
- latil
The damage is exactly like the Chally I was offered years ago,that had caught a missing manhole cover. You've not thumped a big pothole or kerb recently?
