upper ball joints
- latil
Before you undo them, clean off any rust etc on the exposed few threads.Otherwise as the thing unscrews any muck is dragged through the threads in the arm,which are quite fine and can easily be stripped.
When fitting the new ones check and double check that they are not crossthreaded on the way in to the top arm.
real bitch of a job, as said clean threads up then I really heted the wishbone up & gripped the the flats of the ball joint in a vice & wound the wishbone off of the ball joint, real difficult to do, no tools except & vice & lots of heat
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
- Dave-R
That is why it is easier to do it with the UCA still attatched to the car Andy.
You have to be really careful with the UCAs as you can bend them if you put them in a vise.
I have the correct B/E socket too if anyone needs to borrow it. It has a 3/4 drive for a big brake bar but I also have a 1/2 inch adaptor so "normal" sized bars will fit.
check also the quality of your replacements
if they thread doesn't look the same send em back.
there are some really rubbish ones around with a V poor thread.
mainly from china, sold by both US and AUS ebay suppliers.
there is no way in hell they will go in without damage to the arm... i.e you tie yourself into always using this brand if you manage the task as they end up destroying the original thread.
probably a bad batch as the aussie message boards were a buzz with this last year once the exchange rate swang in their favour and it became worthwhile investigating parts from foreign shores.
once its in the wishbone, id put a couple of welds on a well, wish id done this when I had the coronet apart, this is both you & neil this has happend to recently
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
