mallory ignition parts
who's the best supplier for mallory ignition parts in the uk? trawled the net and couldnt find anything, the reason being that i have found one of my terminal posts on the coil is slack, and when i moved it with my finger, it released air pressure! thsanks for any info trev
Trev
FBO do there own coil that would work fine, take a look and let me know if your interested, also take a look at the tech pages
http://www.4secondsflat.com/Ignition.html
Neil
Just remembered DOH,
we've got some FBO A688 ignition kits coming Trev,
which contain
Cap
Rotor
ECU
Coil
Ballast Resistor
for ?65 plus a little bit of postage to you maybe
hi will, sorry have not replyed sooner been away this weekend, i have sourced some mallory leads, rotor and cap so will stick with that set up for now,but thanks for the offer, still want the regulator though bye for now trev
Ok Trev,
the stock order should be shipped today so i ought to have the reg by the weekend
Neil
