96/97 ram auto box
96/97 ram auto box
Hi a mate of mine has a ram but the box needs looking at anyone happy to do this :help: It is holding in second gear and Rev's out before changing up or you have to back off the gas for it to up shift :roll:
Paul
really needs a scanner on it first, and one that will read chrysler interface, OBD scanners wont BTW
also buy a workshop manual (Dodge not haynes) just might save your mate ££
Powerail
Post by Powerail »
Hi Paul,
I'd check the TV/Kickdown cable is functioning OK. I'm guessing if its stuck this might result in something like you described?
Also does it get serviced regularly? Check the transmission fluid/filter.
Also if he changes the filter himself, its worth adjusting the bands whilst you are in there. You'll need an inch/pound torque wrench.
Hope this helps as they are all easy/cheap things to try, otherwise it could get expensive :(
Daniel
