auto gearbox & shifter info
the dodge
Post by the dodge »
being new to an auto gearbox can anybody explain (with pics if pos) the difference between a reverse pattern gearbox/shifter and a "standard" type is there difference in the gearbox if so what? also what is the advantage of having a reverse pattern shifter?
cheers
A reverse pattern is used mostly on the strip , simply put....
P.R.N.D.2.1. becomes P.R.N.1.2.3. , just in case you cock up on the shift & go from 2nd into neutral :shock: , don't like to use a reverse pattern on the street (no kickdown) but a lot of guys on here do.
Sure the tranny boys will give you a more detailed discription.
Reverse pattern are always manual valve body. Manual valve body means no "Drive" function. You have to shift each gear manually. They are also safer to do burnouts in. i.e. prevent the gearbox exploding due to a failer of the overrunning clutch.
..............................just DON'T burnout in 1st gear , reverse pattern or otherwise :shock: :shock:
It's all done in the valve body, swap the auto valve body out, bolt the reverse pattern manual valve body in, job done.
...but you also should change your shifter plate.
Many aftermarket shifters come with changeable gate plates for various shift patterns :thumbright:
Brutus wrote:..............................just DON'T burnout in 1st gear , reverse pattern or otherwise :shock: :shock:
Puts too much load on the sprag (one way clutch) :thumbright:
So does that mean you start your burnout in 2nd, or start in first and then shift quickly into second???
Start in 2nd.......................................
If you have enough power ;)
So how do you stop it kicking down into 1st then ? Or do you have to get so much speed that 1st is impossible ?
I learn something new everyday on this board. !
On a manual valve body of any pattern there is no kick down facility - it is disabled in the valve body.
It is best to come to a halt, then select first to pull away. Matching road speeds to engine speeds is quite critical. They are quite unforgiving if you shift down at the wrong time :(
the dodge
Post by the dodge »
cheers for the info,
good stuff on the a for a bodies site
