Superstock springs
2 clamps on the front section of each spring will be enough, spacing is dictated by where the leaves end, you want to clamp as many of the leaves together as you can to make it more rigid. Sliders allow more spring travel that a shackle, and have the added benefit of reducing side to side sway, which is handy if it gets out of shape. Shocks, now there's a can of worms. Most important thing is that they are long enough. With the body supported on stands and the axle hanging free, you should be able to pull the shock off the lower mount and still have some more extension left in the shock. The Comp Engineering shocks don't have a very good reputation, personally I've had no problems with them. Rancho's seem to have a good following for a "budget" shock. Some guys say you can't get a high horsepower leaf spring car to hook consistantly without quality double adjustable shocks, others say it's tosh
I think run what you have and see what happens. What shocks do you have on the front?
- Cannonball
Re: Superstock springs
9.44 146 mph no caltracs, snubber and loose shox 10.5 tire petepete walton wrote:Was talking to two eminent members of the club the other day about how fast you can go with SS springs and shocks. It was mentioned that Duncan had ran real quick on SSs,, in his cracking Chally. Another one of the great and good mopar men said you can have as much hp as you like but you will only go as fast as the SSs will let you.
Now i plan on keeping my SSs ,,coupled to Comp Engineering drag shocks. Mainly to keep the spirit of the car so caltracs is not an option.
So the question is ,,whats the best shocks for the job?? whats the deal with rear leaf sliders??I know you can put more bands on the front section of the spring .But how many and at what spacing.
I plan on leaving the line at around 4500 to 5000 so tuning the rear springs will be critical for good sixty foot .Any help will be nice
9.44 146 mph no caltracs, snubber and loose shox 10.5 tire pete[/quote]
Way to go Dunc.
Rich.
Way to go Dunc.
Rich.
072
072
