Gear/RPM/Speedo Spreadsheets
I have been asked to post these back up and hopefully one of the Mods can make this thread a "Sticky" so it is kept handy.
http://challenger.mpoli.fi/web/AUTOMATICchart.xls for automatic users.
http://challenger.mpoli.fi/web/4SPEEDchart.xls for 4-speed users.
http://www.challenger440.pwp.blueyonder ... Echart.xls for people wanting to use a GV overdrive.
(no pinion gear section on this as GV supply the correct gear).
I was talking to Demon James last week about speedo gears (no, not swimming pool fashion) and said I'd dig out a chart I had. I found a paper copy.
This should allow you to select the correct speedo gear (easy to replace) to suit your combination of tyre size & diff ratio.
Hopefully the image is legible...
Apologies if this info is included in Dave's links above.
year one speedo gear chart.pdf
(253.34 KiB) Downloaded 468 times
