Rear Axle seal adjustment
GeneralWee
Post by GeneralWee »
Changed a rear wheel bearing and seal on 8 3/4 axle.What does the adjuster do with the seal in on the off side , and how should I set it?
Its the big thing you tap round behind the hub flange, with the interlocking tab.
Thanks
Say hello from Rosco!!
69 Charger, 59 F100, 64 C-10
Austin J40
Austin Pathfinder
X350,V70T,Lifan,2CV,Ducato,Tractor, Actionman, Cindy doll and a remote control car!!
ANTON
Post by ANTON »
its the axle end float adjustment. when i did my seals i marked the position it was in and put it back in the same position. if you want to adjust it and can wait till tomorrow i can scan the instruction for you and post them here.
Anton
GeneralWee
Great.If you could do that, it would help.
Austin J40
Austin Pathfinder
ANTON
Post by ANTON »
i took a photo for you
GeneralWee
Thanks for that - had it just a midgies too tight, but all fine now.
Austin J40
Austin Pathfinder
I don't know what book that is but 8.75 axle shaft endplay should be 8 to 18 thou. Not what it says in that photo.
ANTON
Post by ANTON »
Dave that section is out of a 68 charger workshop manual for a 8.75 rear end.
Anton
Mmm. They must have tightened the spec from '69 on then.
