Barry Grant small parts kits, Demon, Claw and Holley
1 x 120150
These kits contains all the small pieces needed for servicing Demon™, Claw™ and HOLLEY® performance carburetors. Labeled and neatly organized in a durable, divided clear plastic case. 120150 Hardware Assortment Contains a reorder 10 pack of the following:
200003 pump nozzle screw
200004 fuel bowl sight plugs
200007 needle & seat adjusting nut
200009 needle & seat lock screw
200020 idle mixture screw
200073 float pivot shaft
200074 float spring
200075 idle spring screw - 4150/4160/2300
200076 idle spring screw - 4500 models
200088 30cc pump cover screw
200089 50cc pump cover screw
200090 throttle body baseplate screws
200092 butterfly screws - 4150/4160/2300
200094 butterfly screws - 4500 models
200095 accelerator pump cam screw
200096 float bracket screw
200097 idle speed adjusting screw - 4150/4160/4500
200098 idle speed adjusting screw - 4500 models
1 x 120160
200001 pump arm c-clips
200002 secondary linkage washers
200008 needle & seat adjusting nut gaskets
200016 1/8" vacuum plug
200017 3/16" vacuum plug
200019 cotter pin
200021 mixture screw o-ring
200022 pump check needle
200023 pump check valve - Rene
200024 transfer tube o-ring
200025 choke/vacuum cork seal
200026 pump discharge nozzle gasket
200027 sight plug gasket
200028 small bowl inlet gasket
200029 large bowl inlet gasket
200030 power valve gasket
200081 needle & seat lock screw gasket
200087 needle & seat o-ring
Both sell in USA for around $70/$80
£45.00 each + V&P
offers
