Got my recored rad fitted along with steering pump.
Fitted my new water pump with part of my nice new stainless bolt kit but now when i try to fit the water pump pulley it fouls the bolt heads.
Q1, I have washers fitted with the four bolts should i remove these and just use bolts?
Q2, My car is fitted with two electric fans, should i still fit the fan driven by my water pump (direct drive not viscous) and the cowling?
Q3, When i go get ATF fluid am i looking for any special type and is it the same for my tranny and my steering pump?
Thanx, Russ
Oooooh SUNSHINE, Made a little progress but..........
