I,ve been underneath with it running at idle and the noise is slightly further back than a noise from Bananarama! the block and I am totaly sure they are tight
I am sort of hoping that it is the torque converter so that I can strip the trans at my leasure rather than having to so that I can use the car, but I have no idea what a knackered one would sound like. Can they break up inside and have bits of impeller or something rattling around?
I,ve read a little about the transgo kit on the Allpar site and it sounded good so I may try that one, thanks.
Trev, are they just balanced to each other or to the motor as well?
What happens when you stick in another converter? does the whole lot have to be rebalanced?
As for originality, is the converter stamped with anything to identify it to the trans or the flex plate?
This is all a bit of a pain cause I thought my next outlay was to be nice new wheels or exhaust
