Rear brakes sticking?!
Check valve in master cylinder?
Rear brake hose collapsed?
Has your's been fitted with a bias valve? , my 68 only had the distribution block.
Philth
Post by Philth »
The rear hose may look fine but it could be swollen on the inside. This happened to my dad with his old immaculate MG Midget. Failed the MOT on dragging rear brakes. Couldn't work it out at first as the hose looked like new (original part). He just bit the bullet and bought a new hose and fitted it (he already replaced the front hoses). Bled the brakes, no more issues and much better brakes, too. Cut the old pipe to have a look and low-and-behold it was swollen closed on the inside, allowing pressurised fluid through, but no return.
1973 Dodge Challenger
MMA 616
Collapsing flex hoses s reasonably common.
Front ones seem prone. Rubber collapses on the inside so t acts as a one way valve. Press the pedal and the fluid operates the brake. Release the pedal and the fluid is trapped by the hose and won't release the brake.
On the fronts, you can usually push through it and force the brakes off.
I would imagine getting the rears to release would be more difficult.
The bore is the same = no difference.
Smaller bore = more pedal travel but easier to push.
Bigger bore = less pedal travel but harder to push.
Most Mopars have the ports on the fender side.
ANTON
Post by ANTON »
I remake my front to rear in copper. I managed to reuse most of my unions and sourced the rest at a local car part place.
Gravity bleed works best, open the nipples and have several cups of tea :thumbright:
