VAC outlet
VAC outlet
Ok I went to connect the vac pipe that goes to my brakes onto the intake manifold and it wouldn't go on.
After a proper look there was a much metal smaller vac tube coming out of the hex bit which had been bent upwards which was stopping me putting the hose on.
I went to bend it down a bit and it snapped off.
What is this smaller vac tube for?
I think it connects to a thin pipe that goes through the bulk heads.
Can i just put a little screw in it to seal off the intake?
If its vac for the headlight covers then it wont matter for now.
could be the heater control pipe if your car has air con
if the heater control says airtemp on the front in itallic script
then you have a vaccum control for your heater aircon box
this thin pipe will be black and will go through the bulkhead on the drivers side of the car and join with many red and white pipes at a black rubber connector clamped to the back of the heater control .
It should see manifold vaccum rather than vaccum from a take off on the carb .
This little blighter has been the source of many a vacuum leak on mine!
Right, thanks guys.
Its getting a self tapper up whats left of it.
Russ
P.s i meant "much smaller metal vac tube" not "much metal smaller vac tube"
Think i am a little dyslexic but hey, stopped me anything has never doing!
erm, except communicating of course.
