V to P clearance should'nt be a problem with either head (closed or open), you could get away with it with a thicker head gasket if you run into any problems (ideal quench is'nt the holy grail
Just a theory, is there a possibility that the heatup velve in the exhaust being stuck in the closed position for a prolonged period could have overheated the valves and seats enough to burn them out???Dave wrote:One is too rich (or burning oil) and the other too lean. The pale one is the lean. It has been getting hot enough to burn the carbon white.
You sure the valve seats will not clean up with a bit of work with the old grinding paste?
