vacum gauge
On the base plate, under the primary float bowl (where the 'Holley' is on your photo.
Or, on the side of the primary jet plate, above the idle mixture screw, on the far side in your photo (you can just see a little hump which I assume is the rubber cap).
Here's a photo showing both:- vacuum hose to jet plate, rubber cap over base plate.
That's a 600cfm vac sec carb as well.
