Hand brake cable lay out ????
need either pictures or detailed digrams of the hand brake cable layout on an a body........
dustymopar
Post by dustymopar »
Here is the rear part - outer cables are attached to a bracket located on the inside of the chassis rail.
Can take others if you need them
more is possible please dusty, need some of the front sections more.
cheers mate
dustymopar
Pete, I'll try n take some tomorrow morning before I go out :thumbright:
Will email them to you :thumbright:
dustymopar
You have PM :thumbright:
Mick
Post by Mick »
It depends on which setup you have, one runs down one side and splits in front of the axle and the other splits near the front, comes down both sides with 2 shorter cables at the back.
I would think yours would be like Mark's due to the model being the same year.
If it's like the later Duster, i made most of the fittings for mine and if Mark doesn't sort you out, pm me and i'll try and help you.
Mick
