Paul Knight Racing Engines for Sale
Note: All engine prices include dyno break-in & power check.
Sterling prices at current rate of exchange, this will vary
Plus shipping, duty and VAT.
If you have your own preferred shippers I have no problem
with you making your own arrangements.
E-mail for more specific info and pictures.
Chrysler
528 Cu. In. Keith Black Block, B1 Solid Heads, 14-71 Littlefield Blower
W/ Gerardot Injector, MSD 44 Mag.2200 BHP on Alky. Ran 6-teens @ 218 MPH in 2100 lbs. Dragster. W/ Powerglide. Complete with Tune up.
£22,300
623 Cu. In. Chrysler Mega Block, 4.750 stroke Moldex Crank, Fully ported B-1 T/S Heads with Titanium valves and Jesel Valve Gear, Roller Cam, Sheet Metal 2-4 BBL Intake w/ NOS bungs offset NRC Distributor.
£14,340
550 Cu In. 400 Chrysler, Heavy web poured 400 block w/aluminium caps. Eagle Crank, BME Alum Rods, and Venolia Pistons, swapped firing order roller cam & valve train. Fully ported B-1 Moved centreline Heads, Titanium Intake Vales, Charlies Pan w/Milodon Dual Line Oil System, King Demon Carb.
£12,420
491 Cu In. 400 Chrysler. Poured Block w/aluminium caps, Eagle Crank, BMEAlum Rods, Venolia Pistons, Roller Cam & Valve Train, B-1 Original Heads w/ stage 1 porting, Charlies Pan w/ Milodon Dual Line Oil System.
£8,600
471 Cu In. 400 Chrysler Block w/Aluminium Caps, Eagle Rods, Venolia Pistons, B-1/BS Heads & Roller Cam, Blower Drive Services Blower w/2 APD 4BBL Carbs.
£15,920
417 Cu In. Chrysler 340 Small Block, Eagle Crank & Rods, Diamond Pistons, Stage1 Ported 340 Heads, 10 to 1 Comp Ratio. Neutral Balanced,
Edelbrock Performer RPM Airgap Intake.
£5,100
Chrysler Short Blocks
521 Cu In. 440 Block Poured, Aluminium Caps, Eagle Crank & Rods,
Venolia Pistons can be used with following Head Set-ups. B1/B/S, Indy 440-1, Edelbrock, Mopar Stage VI Heads, Cast Iron Big valve heads
£4,780
521 Cu In. 400 Block Poured, Aluminium Caps, Eagle Crank & Rods,
£4,780
471 Cu In. 400 Block Poured, Aluminium Caps, Offset Chrysler Steel Crank, Eagle Rods, Venoilia Pistons, can be used with following Head Set-ups. B1/B/S, Indy 440-1, Edelbrock, Mopar Stage VI, Cast Iron Big valve Heads
£4.150
2003 Dodge V-10 Truck Engine, Complete with exhaust manifolds, Intake throttle body, Flywheel, Fuel rail & injectors plugs and leads.
£4,140
Chevy Engines
598Cu In. Big Block Chvey, Dart Tall Block, Eagle Rotating Assy, Drat intake, Charlies Pan, W/Titan Pump, 15.6 to 1 Comp Ratio.
£8,920
540 Cu In. Big Block Chvey, Dart Block, Eagle Rotating Assy, Brodix Aluminium Heads, Roller Cam & Valve Train, Edelbrock 454R Intake.
£6,370
377 Cu In. Small Block Chevy, Bow Tie Heads, Roller cam & Rockers,
Bowtie 11 Victor JR. Intake, Holly 9380 Carb, Moroso Pan.
£3,820
