Tail shaft case
scott
Tail shaft case
Post by scott »
I keep breaking the rear case on a 727, any ideas what would cause it??
mountings are new,
prop is new,
and the drive train looks in line????
Mopar or No Car
You have a severe case of Heavy Right Foot. I prescribe a Fiat Cinquecento for a month. It won't help but it'll be a laugh to see you drive it!!!
:D
Apologies for unhelpful post! :twisted:
scott
Post by scott »
don't think it would last me a day, let alone a month
Mopar or No Car
tail hsg,s do break occ,
should not keep happening,
you either have an alignment problem or a balance problem, you must
stick with a rubber trans mnt even when you run solid engine mnts or a mtr plate, most break because they have bad prop uj,s also if your a berk and keep burning the car out gettin the rear axle bouncing up and down they break tailhsgs,
hope this helps
scott
Post by scott »
New prop and uj's, new rubber mount.
only happens at the nats every year,
could the shaft be bent ?????????
Mopar or No Car
scott wrote:New prop and uj's, new rubber mount.
possible, you have had a prop let go before i think??? maybe it bent the tailshaft then ??
Cannonball wrote:t also if you keep burning the car out gettin the rear axle bouncing up and down they break tailhsgs,
hope this helps
Scott you might want to try and figure out what you do at the nats every year
scott
Post by scott »
does the box have to be stripped or does it come out the back??
had two props let go both at the rear thats why i had new one made this year.
If it is bent do you have one?? how much??
Mopar or No Car
scott wrote:does the box have to be stripped or does it come out the back??
trans has to be fully stripped the shaft is the last part to take out first part back in, yes will have one £40.00 plus p&p
scott
Post by scott »
looks like i will be taking box out soon. will be in touch Duncan
Might need another case aswell
Wil, the case broke after 2 runs, felt the vibration when it went, never made it to the burns outs this year!!
Mopar or No Car
Was that the tailshaft from my car? I remember sending one to someone. :?
scott
Post by scott »
no dave that is on my mates box as i had borrowed his one !!
Mopar or No Car
scott
Post by scott »
had shaft put on lathe and it is bent and twisted, so,
got a 727 box minus sump for £50 swapped over the rear shaft and casing, but can't remember the specs for tightening the bands,
can anyone help?? Duncan, Blue ??
Mopar or No Car
