Removing parcel shelf..
Ok the plastic bit on top of the parcel shelf has completl;ey rotten.
How do i remove it cant seem to find any fastetners or anything...
I've now got the service manual on cd, but can't find the right part. I assume its called something diffrent being america. Any help or page numbers ect..
Holly
Post by Holly »
I think you just take the back seat back out, and it slides once you've got the vent & fan disconnected.
Best thing is to use the old one as a pattern and cut a new one (from fibreboard or thin plywood) - the one in there is the original so it gives you a clua as to how uninspiring they were!
yep, was thinking of getting some leather and making a new one....
I'll go give it a try :)
Alex
Post by Alex »
Once the seat is out there is usually two small scres holding the seat edge of it in place, then pop up the cntre and wriggle it out, they are a snug fit.
u,mm how to get the seat out? I cant find any screws.. anyhelp...
Alex
Post by Alex »
The bottom, you have to push backwards really hard on both sides then lift it up to clear the locking tabs then pull the seat forward and out, the seat base will be awkward to clear the window handles and arm rests.
The back will be help by either two tabs at the bottom outer edge or by the seat belt bolts.
HTH :hello2:
Holly
Post by Holly »
Get the bottom out first, then you can get at the fittings that keep the seat back in place. Can't remember exactly, but I think you take out two screws just under the front of the bottom piece and it slides forward (or something like that).
Alex
Post by Alex »
Beat ya \:D/
Holly
Post by Holly »
I'll catch the next one hahaha :P
yep, will be more...
ok give that a try when i wake up 2moz...
any idea where the new header bolts are, had a remage about but couldn't find em?
Holly
Post by Holly »
In a cardboard box for an oil filter, within that they're in a plastic boxy thing. They're shiny, and have an instruction sheet as they have cams that stop them from coming undone.
JamesKing wrote:In a cardboard box for an oil filter, within that they're in a plastic boxy thing. They're shiny, and have an instruction sheet as they have cams that stop them from coming undone.
ahh ok cool :) Ill have another look. Probably just assumed it was an oil filter...
Holly
Post by Holly »
They're stealth bolts, lol :D
There is an oil filter in in amongst it all too ;)
