Faster times , Pod or Shakey?
What's the reason better times are had @ the Pod? , bearing in mind it's uphill both tracks are pretty good , would it be due to the wind factor getting slower times @ Shakey? , it seems most pick up around 2/10ths @ the Pod over Shakey , me included. :?
Mick70RR
Post by Mick70RR »
If you've got Google Earth installed, measure the length of both tracks. Looks like the Pod is a few feet short of 1/4 mile and SCR is spot on. Doesn't sound a lot but how long does it take to move the car 2 feet from a standstill?
I always feel like I'm getting better grip at the Pod, the track gets used more and sees a lot more of the faster cars that lay rubber.
Good point Mick. :thumbright:
I don't understand the 2ft from stand still? , if Shakey were a longer track then it would make a difference @ the end of track , how much ET difference 2ft would make @ over 100MPH i don't know.
Mr H. always states that a fastest time at Shakey does not count. ;)
The most accurate timing system is at the 'Pod.
Adam
Post by Adam »
Perversely, I've always found Shakey to be a couple of tenths quicker than the Pod. I put it down to the fact that you usually have the prevailing SW wind behind you, whereas it's in your face at the Pod. Maybe Shakey favours slower cars (like mine) on street tires?
Mick70RR
Post by Mick70RR »
Pete wrote:The most accurate timing system is at the 'Pod.
The timing system at Shakey's is taken to a test house to be certified every year.
Mick70RR
Post by Mick70RR »
I seem to get a better mph at Shakey's for some reason. I was told some time ago that both tracks climb up hill but the Pod climbs a little more than Shakey's.
Was gonne mention the one up Norf , but heard they move the timing counters around. :lol: :lol:
Ok Ok only messin. :D
Time to get to Portreath, all downhill till the last bit, Brutus would be in the 9s ;)
i ave always run faster at shakey, and most people i know
NaughtyAlan
Post by NaughtyAlan »
Its a well known fact that 60fts are better at the pod but doesn't mean you will get a better overall et than shakey.
My best ever ET's have been at Shakey. My best MPH was at North weald, but we leaned very quickly that you just couldn't trust the clocks there, 12.5 @125 indeed.....
DaveB
Post by DaveB »
9.80 shakey
9.93 pod
9.99 york
All fair game in my book,the air makes big difference on my car.
Better stick with Shakey then. 8-[
phil442
Post by phil442 »
Thought your PB was at Shakey (and Al's and Mick's). :dontknow:
