adjustable distributor T
modified distributor T for stock Chrysler electronic distributor
makes mechanical timing fully adjustable from locked out to stock.
1/2 a turn of the grub screw is approx 1 degree
if more timing needs to be removed than the grub screw allows you just use a longer screw to suit
DOES NOT work with a vac can, can has to be removed, the 2 parts of the baseplate tack welded together and a block off plate for where vac can usually sits.
Only adjusts timing spread as in number of degrees timing advances as the rpms increase, does not adjust the rpms, you need springs for that.
I have 2, one is restricted more than the other
I don't use these anymore as they take way too long to modify
£30 each
