Project "Hell hath no".... '64 Fury
Well if I get it, I will know tomorrow I do have plans.
At the moment, I am looking at 4 bbl intake, carb and TTI's
From what I have read, that will perk the 318 Poly up a tad, Then slide the nitrous plate under it for weekends, from what I can gather with a 100 shot of nitrous, that should give me around 370- 390 HP.
Need a Suregrip rear end, as it is an open diff at the moment. I can also get 8 or 9 inch steels for $90 each.
As for the body, well in a year or two I have plans, Spoken to a few people that have done this conversion.... I can get the doors for $250 a piece (glass ones) The pillar is easy to relocate I have been assured, the rest is just bodywork. time consuming but easy! I can also get glass trunk, hood, fenders, bumpers! All off the shelf!
So that is a plan, right? Owner just called me, he has a 440 and 727 60,000 miles when pulled 5 years ago $500! Damn!
If you're going to start messing with the back axle Jeff, check to see if it has the original 8 3/4" with the bolt on flanges. Those things are a pain in the arse to service the brakes and a later diff will not bolt straight in. Be best to find the right width axle from a later car and work with that. I'd grab that 440 rather than mess with the poly.....
I know Pete.... But it would have to be off from October/ November till April anyway, due to snow. So 5 months in the shop should be enough time. This will not be in the near future!
This winter will see motor, trans and rear end sorted I hope.
If I get work.... It gets done. If not, it will be a stocker next summer.
- Trigger_Andy
- Trigger_Andy
Dave999 wrote:
ya-get-me??
Only if the Bird is a Cockrell! A Cock in the Bush obviously gathers no Moss, STD's yes, but not Moss, unless you know about my last visit to the Clinic when they had to take a sample...........
