Does anyone know of any glue (or the best glue) to glue plastic that will be brake fluid proof?
I think I have cracked the plastic brake fluid reservoir where it goes through the grommets into the steel master cylinder. I was a bit 'vigourous' in trying to get the cap off, little realising that it is dead easy and simple
Now it leaks from the front grommet area slightly.
Oh, this is the Buick, not the Monaco.
I think I can syringe enough fluid out to be able to pop the reservoir off, see if it is cracked, and glue it, plus check the grommets. Sadly, it seems neither grommets or reservoir are available separately (unless someone has a duff master cylinder with good resrvoir).
It could be a £60 mistake if I can't fix it.
Damn.
ATB
