Wiper help!
Wiper help!
I am trying to free off the arms that have not moved for years.
The part that the wiper arms fit to, are solid, I have tried spraying them with lube and wacking it with a hammer! it has moved abit!
Do they need to rotate 360 degrees?
Just so you know which part I am talking about, its the sections that bolt under the dash and come out on the scuttle panel.
Cheers,
Morgan.
they only move as far as the sweep of the arm and blade,you could try taking them out and leaving them in a bucket covered in diesel fuel for a day or two.
yes take the spindles off the car hold one part in a vice and try working them very gently back and to plenty penetrating oil slow job but useually works
Two lanes: cheers dude, I will try and soak them in something, only thing is I took them off and cannot remember the way they went back on so dont know how much I need to make em move! DOH!
Dunc: spent ages moving them in the vice with pleny of spray at both ends, they still stick in areas but will keep trying! will give em to my mate to soak em, they have not worked for a while have they?!!!
Cheers guys, I did lose the plot today! was hoping to step to the front on the alternator and the wiring, keep seeing these sunny days and all!
Morg,
